Re: See the pic... thanks.
Don Ohio /
Okay.......you're on the side of the bike opposite the variator,right? Cause the variator is NOT left hand thread until you get past the outer nut.
You have a square-drive wrench ready to twist? Then twist it clockwise to loosen.
Here's what it says: Attach flywheel wrench to the rotor
Loosen the rotor nut(left hand thread) using the square drive wrench,100023
Remove the rotor
Screw the cam puller onto the cam,etc.
Does this help? don-ohio (:^)
