How to remove stuck flyweel nut ???
I want to remove flywheel nut... mine is a solid flywheel, i removed the plastic cover and now i have acess to the flywheel nut... i have already the square wrench and also the wrench to hold the rotor and prevent it from turning... i tried and tried and it doesnt move... nothing, and i have enough strenght.
My is a motobecane V51 1981, i put here the engine pic. i want to know if i have to move the wrench counter clockwise or clockwise to take it off... i also would like some advices to loose the screw... i think its stuck.
thanks in advance.
Ricardo
www.motoretas.cjb.net
Re: How to remove stuck flyweel nut ???
try an oil filter wrench?
Ricardo Oliveira /
yes... i have the proper wrenches...
spray mad wd40 on it
get a freind and hit the wrench with a hammer while you hold on to the oil filter wrench
when Ive had similar problems I spent like 2 hours and finally got it done
It takes a lot of work
Richard Wisniewski /
counter clock wise i belive
left hand thread
Dave Chudak /
it says left hand thread in the manual.. so i assume that means counter clockwise to loosen?
anyone?
Re: left hand thread
John Joedicke /
Left hand counterclockwise, you've got it Dave/Ricardo. JJ
sweet.. thanks double
Dave Chudak /
thanks double
i thought so, but when it doesn't budge at all, you begin to second guess yourself... hehe.... it's a stubborn nut.
WRONG...CCW to TIGHTEN!
He said CCW to LOOSEN............NOPE! Left-hand thread is opposite normal rotation to loosen. Okay? don-ohio
thanks for clearing this up don
Dave Chudak /
thanks don...
so it's cw to loosen then, right?
thanks
Ricardo Oliveira /
I
See the pic... thanks.
Ricardo Oliveira /
I
Re: thanks for clearing this up don
Yep! If it's left-hand thread,clockwise loosens it. I was afraid you might overtorque and break it. don-ohio
Re: See the pic... thanks.
I can't see the pic here from work, so I'll go get my manual.
HOLD ON! Wait `til I get back here! We don't wanta' turn a right-hand thread to the right.....that'll tighten it. If the manual SAYS it's a left hand thread, you turn it clockwise to loosen it. don-ohio
Okay.......you're on the side of the bike opposite the variator,right? Cause the variator is NOT left hand thread until you get past the outer nut.
You have a square-drive wrench ready to twist? Then twist it clockwise to loosen.
Here's what it says: Attach flywheel wrench to the rotor
Loosen the rotor nut(left hand thread) using the square drive wrench,100023
Remove the rotor
Screw the cam puller onto the cam,etc.
Does this help? don-ohio (:^)
Another thing........I wouldn't use an impact wrench on it, unless you can turn the torque down to 50lbs. and hope it breaks loose. REMEMBER...CLOCKWISE to loosen! don
Ricardo Oliveira /
i already did it.
see my new topic how to clean the points.
ricardo
