Puch Maxi spark problems
I just got back my moped engine from the shop (it had a new compressor put in and spark plug check as well as timing, and before that it was in for a new starter cable) and remounted it. With much trepidation, I tried to start the engine: and of course it didn't work. Checking the spark plug against the cylander head, I found there was no spark being generated: I checked the wiring at the junction harness and I know that the spark plug works (it was tested in the shop). What else should I do?
Re: Puch Maxi spark problems
Jason Luther /
kill switch? just start with the basics and work your way back. they may have loosened something while replacing parts.-jason
Benjamin Meyers /
I found that my tail light bulb is burnt out: but I have found no places that sell 5 watt 6 volt bulbs: any suggestions?
Jason Luther /
did you try radioshack? or a motorcycle shop?-jason
Call ike at 1-937-446-2115.......he's got a boatload of original Puch bulbs. Also Mopedwarehouse has `em and Handy Bikes. Take yer pick. don-ohio
