Re: 79 Puch 2speed
Bradford Wirt /
This is Brad again. One thing you want to do first is check the adjustment nut near the tranny case and make sure it is properly adjusted. Also, check to see if you have proper free play (3/4") in your clutch lever. Of course start with the most simple and obvious things first before ripping off into the tranny case.
Brad
