My mobylette leaks gass
my moped leaks gas (motobecane--mobylette)
the black box behind the engine and carb. there is a grey plate on it witch is built into the carb.. well at the bottom there are three holes.. thats where it is leaking from...
im qwite dizzy from trying to fix it .. seeing as it leaks .and the smeell of gas fills the air...
please help me
thanks
corey
gas leak
Dave Chudak /
im not too sure.. i have a small leak too... i am going to take my carb apart.... im guessing there are some leaky seals... you may want to do the same... rebuild kits are pretty cheap i think....
good luck to you ... i hope it all works out
