Sachs 504 Jetting/Carb
I have my '77 Sparta running nicely but it goes only about 20mph. Anyone know the Jetting and Carb sizes and the top speeds? I had a '70s Sparta before and I know it went faster than this one. The Bing I have is a 85/10/101.
Any help would be great.
Thanks,
Fred
Re: Sachs 504/1 A, Jetting/Carb
First thing you need to do is get the bigger carb, the 85/12/101 with a #52 jet. That will help alot and it should run approximately 28mph.
Right now you have the 85/10/101 with a #50. That is the biggest restriction on the moped. Otherwise mess with your gearing.
Use a translator on this site: http://www.newsachsmotor.de/bis_50_ccm/504/504.html
and find out the exact specs for your 504 motor.
It might be a 504/1 D, or 504/1 B which were made to go slower, mostly restricted by the carb size.
