kill switch
Does anyone know how the kill switch works? does it take power from the coil and ground it out? recently my kill switch stopped working and I cant figure out why. Maybe a dirty contact or a loose ground. I figure if I know how it works, Then I can trace the problem. I have to pull the spark plug wire to shut off my moped.
Re: kill switch
Angelo Massimino /
The kill switch grounds the wire coming from the points and stops the "info" that goes from the points to the high tension coil.
