Tomos turn signal problem
Alan Herrington /
Tomos Targa 00 or 01
My left turn signal isnt working properly, may be shorting out somewhere. It worked fine earlier today, but is now very dim and when the left signal is on the headlight turns off and on opposite from signal. the right signal is fine. any ideas?
Re: Tomos turn signal problem
Probably bad ground on that signal. Check the ground connection from the bulb socket. don
Either bad terminal connections or if you have the polarity of the turn signal reversed will cause this problem. Check them both.
Chris MWH
www.mopedwarehouse.com
www.mopedguru.com
Alan Herrington /
Hmm, Couldnt be polarity @ the socket, because the left front and left rear signals were working fine earlier today. it seems like the left side shorts out the whole system. Could either of you familiarize me with the parts on the electrical system? im pretty good with electronics, i just have never worked on a moped, and if i knew what all the parts were i could begin to test the outputs of them... such as the magneeto and what not. i have a voltage meter. thanks, alan
Just check that socket where the ground touches the side of the bulb,Alan. Then if that's not it, check the ground wire that goes TO that connector to the side of the bulb. it is usually that. If the wire grounds to the fender or frame...check it right there. don-ohio
