Re: 1979 Puch front brake=wheel wobble
Chris H /
It sounds like the play is between the upper and lower fork tube. This is quite common. It probably will need a fork slide rebuild kit. I have them new if needed. Usually you will see that the grooved shell (dust shield) has fallen down and the plastic tits that hold the nylon fork slide bushings have broken off allowing the bushing to slide down and cause the looseness.
Chris MWH
www.mopedwarehouse.com
www.mopedguru.com
