Re: FA50 FUEL HELP!!!
Don Ohio /
It's really easy to miss a passageway in those tiny carbs, and soaking will NOT clear all passages. It helps, but it is not a sure-fire fix. Poking thru those passages and spraying them out will cure the problem unless it's ignition usually. don
