Re: WTF replaced throttle cable - now won't start
David Williams /
Ok... I replaced the fuel petcock and bowl gasket.... and I cleaned the float valve... but it still won't start. It did sputter for about 4 seconds before dying. After that it wouldn't even burp. When I try cranking on the engine a few good times, fuel starts dripping from the exhaust pipe where the header meets the baffle. When I took the exhaust pipe off and tried cranking away, a spray of gas formed on the pavement below. Should it be using this much fuel?
Thanks
  WTF replaced throttle cable - now won't startTopic by: David Williams David Williams 04/05/04 08:59PM
  Re: WTF replaced throttle cable - now won't startRe: Jason Luther Jason Luther 04/05/04 09:40PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/05/04 09:53PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/05/04 10:40PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/06/04 04:18AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/07/04 07:17PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/08/04 02:00AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/08/04 04:30AM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/08/04 12:19PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/08/04 12:23PM
  Re: WTF replaced throttle cable - now won't startRe: John John 04/08/04 12:56PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/08/04 07:17PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/10/04 06:00PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/10/04 06:54PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/10/04 07:09PM
  Re: WTF replaced throttle cable - now won't startRe: Don Ohio Don Ohio 04/11/04 01:41AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/12/04 10:36PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/13/04 11:51AM
