Re: WTF replaced throttle cable - now won't start
Bill W /
It is difficult to tell but best to replace the float needle valve if you are having a flooding problem.
It doesn't take much of a indentation in the tip for the gas to find a way to seep through.
Best to bring components up to oem specs when you are trying to correct a problem.
Anyway good luck with your project and let us know when you get the carb parts and hopefully that will solve the problem.
  WTF replaced throttle cable - now won't startTopic by: David Williams David Williams 04/05/04 08:59PM
  Re: WTF replaced throttle cable - now won't startRe: Jason Luther Jason Luther 04/05/04 09:40PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/05/04 09:53PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/05/04 10:40PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/06/04 04:18AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/07/04 07:17PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/08/04 02:00AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/08/04 04:30AM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/08/04 12:19PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/08/04 12:23PM
  Re: WTF replaced throttle cable - now won't startRe: John John 04/08/04 12:56PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/08/04 07:17PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/10/04 06:00PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/10/04 06:54PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/10/04 07:09PM
  Re: WTF replaced throttle cable - now won't startRe: Don Ohio Don Ohio 04/11/04 01:41AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/12/04 10:36PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/13/04 11:51AM
