Re: WTF replaced throttle cable - now won't start
Bill W /
Yes too much gas could keep it from starting (flooding), Depends on the weather conditions in your area at the time you are trying to start it.
I've seen them leak so bad, gas runs out the tail pipe when it is just sitting, not running.
While you have the carb disassembled clean the chamber where the float needle valve slides up and down. Sometimes varnish gunh can build up inthere and obstruct the full range upward movement of the float needle valve. This would agin cause the flaot needle valve to seat properly and gas to continiously flow through.
  WTF replaced throttle cable - now won't startTopic by: David Williams David Williams 04/05/04 08:59PM
  Re: WTF replaced throttle cable - now won't startRe: Jason Luther Jason Luther 04/05/04 09:40PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/05/04 09:53PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/05/04 10:40PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/06/04 04:18AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/07/04 07:17PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/08/04 02:00AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/08/04 04:30AM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/08/04 12:19PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/08/04 12:23PM
  Re: WTF replaced throttle cable - now won't startRe: John John 04/08/04 12:56PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/08/04 07:17PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/10/04 06:00PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/10/04 06:54PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/10/04 07:09PM
  Re: WTF replaced throttle cable - now won't startRe: Don Ohio Don Ohio 04/11/04 01:41AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/12/04 10:36PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/13/04 11:51AM
