Re: WTF replaced throttle cable - now won't start
Bill W /
Sounds like you have a couple of problems with your carb.
First, sounds like you may be sucking too much air through that defective float bowl gasket. Air leaks can make starting difficult or impossible.
Second, the float needle valve sounds like it needs to be replaced. The float needle valve is attached to the float and is supposed to move upward and blocked the flow of gas when the bowl is full. The float needle valve has a rubber like pointed tip that becomes worn with a ring indentation and will no longer stop the flow of gas.
You can order these parts from Ike's Bike or Moped Warehouse or your favorite moped dealer
  WTF replaced throttle cable - now won't startTopic by: David Williams David Williams 04/05/04 08:59PM
  Re: WTF replaced throttle cable - now won't startRe: Jason Luther Jason Luther 04/05/04 09:40PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/05/04 09:53PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/05/04 10:40PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/06/04 04:18AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/07/04 07:17PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/08/04 02:00AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/08/04 04:30AM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/08/04 12:19PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/08/04 12:23PM
  Re: WTF replaced throttle cable - now won't startRe: John John 04/08/04 12:56PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/08/04 07:17PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/10/04 06:00PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/10/04 06:54PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/10/04 07:09PM
  Re: WTF replaced throttle cable - now won't startRe: Don Ohio Don Ohio 04/11/04 01:41AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/12/04 10:36PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/13/04 11:51AM
