WTF replaced throttle cable - now won't start
David Williams /
Ok, the damndest thing. Last week my moped ran great... until the throttle cable broke inside the carb. I removed the carb and spark plug (to be cleaned) and waited for the new throttle cable to come. (I cleaned the head of the spark plug with a wire brush to clean it off) (Also, my fuel valve leaks internally, so it tends to flood the carb over long periods) Today after i installed the new throttle cable and got everything back together, it wouldn't start. Fuel delivery is fine, compression, spark, all good. I also noticed fuel was getting into the exhaust header. When i removed the spark plug to take a look, it was all wet with gas. The odd thing is that when i remove the spark plug and check for spark it's fine. Could the timing be off? Even though it hasn't been touched in a week?
  WTF replaced throttle cable - now won't startTopic by: David Williams David Williams 04/05/04 08:59PM
  Re: WTF replaced throttle cable - now won't startRe: Jason Luther Jason Luther 04/05/04 09:40PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/05/04 09:53PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/05/04 10:40PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/06/04 04:18AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/07/04 07:17PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/08/04 02:00AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/08/04 04:30AM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/08/04 12:19PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/08/04 12:23PM
  Re: WTF replaced throttle cable - now won't startRe: John John 04/08/04 12:56PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/08/04 07:17PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/10/04 06:00PM
  Re: WTF replaced throttle cable - now won't startRe: Bill W Bill W 04/10/04 06:54PM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/10/04 07:09PM
  Re: WTF replaced throttle cable - now won't startRe: Don Ohio Don Ohio 04/11/04 01:41AM
  Re: WTF replaced throttle cable - now won't startRe: David Williams David Williams 04/12/04 10:36PM
  Re: WTF replaced throttle cable - now won't startRe: Bruce Wilkinson Bruce Wilkinson 04/13/04 11:51AM
