motron no spark
Kenneth Adkins /
Just bought this motron there is no spark at all but the lights will come on
Re: motron no spark
Motron is Minarelli powered,at least all I've seen have been.
Check the kill switch up on the handlebars and the wire going to it. They go bad sometimes asnd ground the kill wire even when turned to `on'.
Check the taillight bulb also. But most of those grounded thru the brakelight bulb,I believe, which means if the brake bulb burns out, then the spark won't occur every time you hit the brakes.Been there....suffered that!
Usually,though.....it's either that stinkin' metal-headed spark plug boot or the spark plug itself, or the points need filed and regapped to .016". don-ohio (:^)
