77' Puch maxi - No spark
I was riding and the revs were maxed out. Then The engine died and I have no spark. Did i burn something out w/ high revs? Has this happened to anyone? Is there a quick fix, or should i start digging. Thanks ben
Re: 77' Puch maxi - No spark
Richard Wisniewski /
hey check the point gap ...and see if the key thats slotted into the magneto isnt busted.if not then it might be a coil porblem
Rich
Any idea what the point gap should be set at? I will also check the key. Thank you
per the manual, gap it at 0.016 - 0.020" (0.4 - 0.5 mm)
oh, sorry, that's the spark plug gap. my bad. i had spark plugs on the brain...
per the manual, POINT GAP should be: 0.0137 - 0.0177 in. (0.35 - 0.45 mm)
Jason Luther /
just use freds 'small cereal box' feeler gauge.-jason
