Re: I cant turn the lights...
Chris H /
To clean your points you must remove the flywheel. You will need to remove the nut that holds the flywheel on . It is Left hand threaded (reverse thread). Also do not use sand paper. Use emery cloth. Sand paper is made of silicon carbide and is the last thing you want to embed into your point face.
Chris MWH
www.mopedwarehouse.com
www.mopedguru.com
