Honda express gas leak
I have a 78 Honda express...when you put fuel in.... the gas just leaks out from the shut off valve. Anybody have any ideas?
Re: Honda express gas leak
I just had the same problem. You can disassemble it and replace the washer inside unless the washer is no longer available. THen you would have to replace that valve (petcock). Being it is a honda you can probably get one from any honda dealer. I had to go with a universal style because they dont make mine anymore. That would also be a good time to replace the fuel line if it is in need.
I got mine at www.myronsmopeds.com.
good luck
