Re: air flow problem
Greg Brown /
Im just learning about this mopeds but if I had to guess I would say you have trash in the main jet of your carb. You will need to pull carb off and take it apart and clean it. Watch close as you take it apart and make notes if you need too. The main jet is in the bowl of the carb, just above the float. Replace the filter and you should be ready to go.
