Re: sachs repair
Cpt. F. /
The decompression cable to engage the engine is available at <www.mopedjunkyard.com>. You can also order a headlight there. The battery is not required to start the engine, it is only for turn signals.
Otherwise, just make sure the carburator is clean, mix your gas 50:1 using two-stroke oil, and there's Type F Automatic Transmission fluid in the transmission.
  sachs repairTopic by: William Owens William Owens 03/26/04 11:16PM
  Re: sachs repairRe: Cpt. F. Cpt. F. 03/27/04 04:22AM
