Re: motovecane v51 "chokes + drowns"
Don Ohio /
There's no screw that regulates gas flow..........just a certain size jet is fitted into the `diffuser'. You probably as I think I said before, have a bad float or needle valve or dirt in the needle valve seat. I can look in the manual, but I don't think the float has an adjustment? I'm not sure though....and since you're from Portugal, the carb could really be different. don-ohio (:^)
