Puch info
Steve Pollock /
I just picked up a '79 Puch Magnum II the other day which has seen it's share of neglect. I cleaned the carb, drained the old fuel, and replaced the fuel line. With a little effort it started up and ran. I notice while it was running that there seemed to be a lot of play in the drive sprocket. I could see it moving in and out about 1/4" while I reved the bike. Is this normal? I also noticed a similar amount of in and out play on the pedals. What do you guy's think?
Also, do most people use the oil injection or bypass it and pre-mix fuel?
Thanks,
Fritz
Re: Puch info
my pedals always did that also, i never worried about it. i would advise installing an inline fuel filter between your petlock, and carb. it helps tremendously to keep dirt/rust out of your carb.
most people bypass the oil injection because of reliablity, but i've never had a problem. i always add some two-stroke to my tank anyway though. some people like the injection for convenience......stopping at a gas station, and just filling up............
Re: Puch info
Some play in both of those areas is normal. 1/4 inch is a bit much though. The freewheel sprocket is not a precision piece like you would find on a bicycle. Corner cutting at its finest
Chris MWH
www.mopedwarehouse.com
www.mopedguru.com
Re: Puch info
Steve Pollock /
thanks for the information guys. Paul - I did put an inline filter in. Luckily I had one laying around from an older project. Chris - 1/4" was just an estimate bit it is probably close to that measurement. I haven't had the chance to ride the ped yet so I guess that will shed some more light on the issue.
Re: Puch info
Steve Pollock /
I was also wondering...the ped is a '79 Puch and it has a Huret (sp?) speedo on it. I thought Puch had there own speedo's? Is this something somebody threw on it?
Re: Puch info
yes, puch had their own. the speedo probabley went bad on it, and was replaced with your current.
Re: Puch info
Huret is Motobecane's speedo...that's wierd.
