Re: Lights are messed up...
Edward Edwards /
The lights on a PA-50 are on all the time, the brake light only comes on when you stop. Check the rubber boot that is under the left floor cover & see if all the bullet connectors are clean & tight. Follow the cable that goes through the hole in the rear fender & make sure it's not cut where the rubber grommet is. One thing I think you should have is a shop manual ( it help's me out a lot) some are on E-bay for around $20.00 there nice to have. Good Luck
