weeeird noise
i have a weird noise coming from my engine..a sound like a can of nails being shaken up and down. i have heard that this can be the crank seals. well....is it the crank seals?
Re: weeeird noise
can you tell us where it is coming from by any chance?
front of the engine? back? side?
what rpm does it happen ?
how often?
nick
Re: weeeird noise
D Kwesste /
the noise comes from the cylinder any time the engine is on. i think it comes from the cylinder...it's hard to pinpoint the source.
Re: weeeird noise
D Kwesste /
by the way, it's easiest to hear when i am directly above the engine, sitting in the seat.
Re: weeeird noise
yo what kind of ped is it? and is it only at certain times? my TTLX only rattles like that at 15 and 25... (1st shift.. the 2nd one i dont know about..)
Re: weeeird noise
D Kwesste /
it's a peugeot 103
Re: weeeird noise
Richard Wisniewski /
smoke it a joint i do that with my ped and they work fine after,
they just need to chill out once in a while
jk
Rich
Re: weeeird noise
Dan i had this on my puch its the piston.Have you disassembled the cylinder before??? check if you rings are sitting right.
my problem was the circlip fell off my oiston casing the pin to scratch the wall.
Rich
ps. make sure you have good bearings in your bottom end the can cause like a winding chatter noise
Re: weeeird noise
D Kwesste /
well the piston is okay. it pre ignites like a muhfugga, though, and that may have caused the bottom end bearings to start f--ing up...you think?
Re: weeeird noise
pre ignition???thats timing dudeif you dont have a ddial indicator ask a mechanic to do the timing, you just need to know what the specs are for the points and the BTDC and TDC
Rich
