Re: my four stoke seem to get a vapor lock
Don Ohio /
I think you got ALMOST all the dirt out,Shane. Before you tear it down asgain, go to the auto parts place and get a can of STP carb cleaner. Just put 2 ounces in a tankful of gas and run it for a while. Do that a coupla times in a row,but sdon't exceed that ratio of fuel to carb cleaner. I think it will probably work out on its own. Just make sure your valves are adjusted right too. Sometimes they need attention. And always try a fresh spark plug before you do anything else when a sudden problem comes up. don-ohio (:^)
