Re: my four stoke seem to get a vapor lock
Don Ohio /
That has a float bowl drain valve and attached hose,right? Loosen the drain screw and see if you get a lot of gas coming thru the hose. This will tell you if you have a restriction at the needle valve or before the needle valve at carb inlet or even at the petcock at the tank. don-ohio
