Peugeot 103 overhaul
Any tips on taking the two halves of the engine case apart. They are loose and everything is stipped off but they just wont slide apart...
Re: Peugeot 103 overhaul
Warm them up so they expand slightly, then try again.
Use a rubber mallet, and be gentle.
Frank
the case spins on both sides around the crankshaft but they just wont pull apart. is this normal?
I have a peugeot 103 and if I needed them apart i would take them to my machine shop and have them use a press to do it. This is what is recomended in the manuel so no damage is done. I have never needed to remove the halves personaly, so I don't know if theres another way.
