Motobecane
Hami Onder /
I am having trouble starting my 77 motobecane v55. (or something like that) It will start but it needs some massive peddling. i was wondering if it was a problem anyone knows anything about. also, if it were easyer to peddle maybe that would help. anyone know any tips?
Re: Motobecane
Well, Hami, it probably needs the ignition points filed and regapped and maybe a new spark plug? Also is the choke working correctly and the decompressor valve on the head? don-ohio (:^D
Re: Motobecane
Hami Onder /
hami OP
The spark plug is new and the choke works correctly. I am not sure how to file and regap the ignition points. is that something i can do on my own? and can you briefly explain how to tell if the decompressure valve is on the head? sorry about my non-knowingness on the matter, but thanks for the help
Re: Motobecane
Get a shop manual and it will tell you all of this. I have heard it is harder to get to the points on a MBK, though. The nut that holds the magneto on is also,I believe, a left-hand thread. Clockwise loosens it. The decompression valve is cable operated from as lever on the handle bar. It looks like a plug sticking up off the head. don-ohio (:^)
