Re: transmission/powerhead
Don Ohio /
Sounds like you have a blown crankshaft seal on the left side in the gear case. This pressures up and blows the pedal shaft seal. Replace both crankshaft seals(the other one's under the stator plate beneath the magneto) and it should be fine. don-ohio (:^)
