Puch Maxi Bogs out
I have a 77' Puch maxi. I rebuilt the motor w/ seals, bearings, rings, etc... The ped starts and idles fine. When I try to power up, it bogs down heavily. I've cleaned the carb three times now. I think its a carburation problem. Could be ignition. Any advice is good. Ben H
Re: Puch Maxi Bogs out
Make sure the airbox is properly restricted. My Maxi Sport didn't run properly until I taped over half the airbox hole, as it was missing a plug that goes in the hose that sucks air from inside the frame. Other than that, try cleaning your carb really well.
Chris Couillard /
Adjust the carb it is either getting to much air or gas check the plug is it wet
did you clean, and reset your points?
check your timing, possiblity........
Hey Matt, i Tried the restricted airflow solution you were talking about. It worked perfectly. thanks. ben
Booyah.
