Re: What is good compression on Minarelli V1?
Don Ohio /
Minarelli has an 8:1 compressio ratio. Look for anytrhing above 95 lbs. to run okay with Minarelli and only regular gas is needed. Shave the head .020 to up the compression, if the rings,piston,wrist pin, and rod bearing, check good. don-ohio (:^)
