What is good compression on Minarelli V1?
The subject says it. I am just trying to narrow down my problems, what is acceptable compression on Minarelli V1?
Thanks,
Justin
Re: What is good compression on Minarelli V1?
Minarelli has an 8:1 compressio ratio. Look for anytrhing above 95 lbs. to run okay with Minarelli and only regular gas is needed. Shave the head .020 to up the compression, if the rings,piston,wrist pin, and rod bearing, check good. don-ohio (:^)
