no power for my puchmaxi sport
ok i put 14 mainfold on it 14 mm carb too and rebuilt the motor now it starts in one pedal but now my problem is no power like it take me a cross the stret and back but seem like there no air flitler on it ...it just coughts and dosent pull when i gas it all the way i have air filter but it acts like there no air filter like when i lift the wheel up and gas it alway to goses prety fast do u know my problem is or how to fix this problem u think air leak or what let me know your ideas ok thanks
Re: no power for my puchmaxi sport
You may have the opposite problem--not _enough_ air. Try messing with the amount of air going into the engine. Leave the air filter off for a short ride (don't overheat the engine) and see what that does (or derestrict it some other way if possible). If you're using the stock 50cc cylinder, I wonder if a 14mm carb may be too much for it. I'm not sure on that though. You probably have a larger cylinder anyway.
try raising the needle in the carb one notch and see how that affects it.
Chris
Did you make sure it was timed correctly? Check for air leaks?
You are nearly 9 years late to the party.
