puch problem any ideas
Chris Couillard /
does anyone know were I can gut a motor for an 80"s puch
I amworking on a friends bike and the motor was not ran for 4 years and now it crank bearing I think are gone
and there is some kind of wiring problem
WHen its runing you hear a loud rapping and when you turn on the like it stays on for about a min. and turn it self off
there is no blow by and the piston is in good shape
carb is in good shape the hole bike is in good shape . or could it be the tranmission were would I get part for it
Re: puch problem any ideas
Jason Luther /
i wouldnt think your motor is bad, my puch made a clinking noise, it turned out to be a seized chain link., just clean the carb well, its probably flooding-jason
It's probably a noise coming out of the tranny. don
If it has been sitting for 4 years, do your due diligence and clean and flush the tank, fuel petcock and carb. Inspect and clean the points if needed. Adjust the idle and see if it will idle properly.
If it still dies after the minute it's could be a bad condensor.
Drain and refill the tranny with ATF type "F". 1 speed tranny (round side cover) with 5.5 ozs of ATF. 2 speed takes 9.5 ozs. (retangular side cover) DON'T top it off or overfill if it is a 2 speed.
Go over the bike and make sure everything is properly tightened down and the drive chain is adjusted correctly, not too tight and not too loose (chain slap).
After all this and it runs OK but stll makinga clattering sound and low rpms, then report back.
