Moped keeps blowing lights
How come since I put preformance parts on it the lights keep blowing out.
Re: Moped keeps blowing lights
If you're running higher rpms,there is more current going thru the lamps. Just increase your bulb wattages by 20% and see how it does. don-ohio (:^D
You could also add more lights in line to draw some of that extra juice.
How about a moped with Ground Effects?
If upping the wattage doesn't work, try 12V bulbs with the same wattage as the correct 6V bulbs...
hmm but according to my puch manuel it says that it has ac fr high or low rpms so it shouldnt but i have the same problems
6=LESTER
and maybe throw a sweet 1000 watt system in there too?
Jordan Smith /
Well um it already is a 12v system. How the hell can you put a 1000w system on a moped?
Are you sure the bulbs are 12v? Most 12v volt systems use a combination of 12v for ignition and accesories and a 6v coil for main running lights. I sort of agree with Don-Ohio. More RPMs means more voltage, which in turn means more curent, but its the voltage that's killing your bulbs.
Jordan Smith /
Ok so can you get some sort of regulator?
