puch timing so bad...
the puch i was working on had the timing set so bad the thing went backwards!! peddles going fast as shit and everything!!!
Re: puch timing so bad...
If it was that bad,it probably has a sheared flywheel key. don-ohio
i don't know it's fine now been riding it for two days. no problems.
what exactly is the flywheel key?
It's the little half-football shaped tab of metal that fits in the crankshaft groove and the magneto groove to keep them aligned. don-ohio
oh, cool. it's fine then. thanks
I doubt if it's fixed Pat, it will eventually give you problems again, so you might as well replace that key.
the real name fr it is a woodruf key u can prolly do what i did and go to the local hardware store find the one closest to the same size and grind it the rest of the way i mean if u want
Troy Brown /
how do you know when the two are lined up?
Patrick Mattison /
the key fits in the slot when it's lined up.
Troy Brown /
it seams like there is still a gap when i tighten it down
This happened to me as well just the other day. The amxi in question runs very poorly, and i though it could be over-advanced timing. At both extremes of the stator twist range, it will occaisionally start in reverse, and has terrible low end. It takes a city block to get up to 15 to 20.
Can the stator be attached in the wrong position? I thought there was only one way it lined up right. My woodruff key was on and in good condition.
weird i put this post up almost 2 years ago.
Just wondering did you have to replace that woodruff key in 2004?LOL.Jim
napa and other auto stores usually have a wider selection of woodruff keys, sometimes you dont even have to grind them down
i,guess i did, i don't even remember, i've worked on so many puchs.
Gotta love a backwards running motor.
My friend has a Derbi 50cc supermotard and they have a sporadic problem of running backwards. It would actually drive in reverse (really wierd looking)
