1988 Suzuki Fa50 starting problem
Robert Bentzel /
If any one can help with this I would be greatfull. I have a problem with cold starting this moped. When you first try and start it with the choke in it will run for a few seconds and then shut off. You have to go through this about 15 times then it will finally start and run with no problems. The bike can be shut down and restarted also with no problems. However if you leave it sitting for 30 minutes or so. It again is very hard to start Any help would be appreciated.
Thanks,
Robert
