Re: My Motobecane is running rough, HELP
don-ohio /
It's probably what Ron said,but do a compression check if it isn't.Since it was sitting that long,the rings could be partially stuck,and this cuts suction thru the idle passages.Always hold the throttle open when you check compression. Hope you solve it! BYE!
  My Motobecane is running rough, HELPTopic by: Bruce Matthews Bruce Matthews 04/30/01 02:16AM
  Re: My Motobecane is running rough, HELPRe: Ron Brown Ron Brown 04/30/01 03:53PM
  Re: My Motobecane is running rough, HELPRe: don-ohio don-ohio 05/10/01 05:48PM
  Re: My Motobecane is running rough, HELPRe: ross ross 05/21/01 11:00PM
