Lower end is SEIZED. So WTB a working flat reed.
Cornped is doing a rebuild series on flat reed right now!
Well start V but it should be close right?
Just rebuild the motor
That’s an option and I probably will.
Full engine rebuild would be your best option
May be a good time/opportunity to explore Derbi power beyond 49cc
It’s really not that hard the manual explains it very well, I haven’t had much luck of the gaskets fitting off treats so might want to cut your own
I am rebuilding a Start V right now. If I were you I'd just rebuild that one. Then you know its good. Buying a used bottom end is a gamble. I bought this one and thought it was good but the bottom end seized after 15 miles.
euro "world champion" is similar enough to start v.. US variant sport and america kind of, not really..
Great video. Kind of shows me what up up against when I go for mine. Not sure what equipment I can substitute for that hydraulic press since I do t have one of them or access to one. Also I have about the same bearing puller kit shown when you had a choice of three and none of the ears were sized to grab the bearing and you welded it. I have to think on how to do that one and of course I don’t have that bearing puller off the crank tools but I guess I can buy em where you did. Thanks (edited)
Look up “bread trick” to remove bearing without a blind puller.
I think I posted about it because I actually used it to successfully remove/rebuild an engine. (not my proudest moped moment but it worked!)
Heat up the cases around the bearing and then smack it on a block of wood works for me
yeah, you dont need a press. you can use the crank bearing puller on that shaft.
and if you put the case in an oven at 350 the bearing would fall right out after 5-10 minutes.
StartV is much easier to rebuild since there is basically nothing inside of the motor apart from a crank, couple gears and input and output shaft.
Be VERY careful pulling the electric start off! There’s spring loaded ball bearings that will fly out and disappear if your not careful. Other than that it’s a walk in the park. Just lit the bolts with some lube/penetrating oil and your Good to go!
This thing is a mess. The electric start side is seized and you can see how high the water was inside the orbital gears parts. Jackerz, all the sprague clutch rollers and springs are not in there. The clutch and variator slid right off the crank shaft. The crank shaft will not budge. This piston and connecting rod will not budge. But I guess I will crack it open next. (edited)
No, this is not like a start V… the internals are different.. a euro flat reed is similar. This US motor has a different pedal shaft set up. That video is not gonna help much .
Good luck ^_^
ope, sorry dude. Good luck.
Dude just get the manual it is really helpful
If you do want/need an extra ds motor i can ship ya one.
Is it from a ds50 and can I see some pics?
