I know you can get aftermarket on Treats, but the quality is hit or miss. I'm sure someone here has an original one that's used.
Doesn't need to be fancy and pristine. Just needs to work.
The buzzeti ones really are top quality. Better than stock, waaaay better than the cheaper ones. I've got a bucket full of stock ones if you really want one but I'm telling ya, the buzzetis are where its at
Second that buzz are top notch. Just need to assembly and good to go
If it's cheaper shipped than the Buzzetti then I am interested.
The only reason I don't have one is someone "deleted" it years ago and just made a chain to the exact length. Now it's getting harder to adjust the slack on both chains and it's time to fix it. (edited)
are you setting proper tension?
Yes. Someone just cut one to length and it didn't wear at the same rate as the drive chain so it's annoying and time to get it proper instead of half-assing it with chains cut to exact lengths.
