Lol if anyone is vent outta shape, it's you. What do you gain by shitting on someone's efforts? I'm not spending your money, and at this point I wouldn't sell you one even if you wanted it.
You've clearly got very little experience with additive manufacturing of any kind if you think "most 3d printers are up to temp at 180." That's barely enough to melt the lowest temperature materials sold for FDM 3D printers, not to mention the fact that those are a tiny fraction of the market. Even materials I would never consider using for a project like this require at least 30 degrees higher temp than that.
You even said yourself, a case inducted two stroke won't get anywhere near as hot as a piston port would, so at worst I'm only gonna be able to do half the mopeds on here. What a shame! I should just give up now.
You're completely ignoring the fact that the end of this is a library of 3d modeled intakes that can be used with any number of manufacturing methods, even the *~©METAL©~* you love so much.
Your perspective reeks of "BACK IN MY DAY WE DIDN'T LET PLASTIC MIX WITH METAL, IT'S NOT NATURAL"
You can't or won't provide anything to back up your claims except "THAT'S THE WAY IT'S ALWAYS BEEN" and you make nonsense assertions like "the tests have been going on for decades"
lolllll the world is dumping a ton of money into small displacement two stroke engineering these days, eh? Which companies are those again?
Get fucked. Even if I can't make a single good intake, I'll die on the hill that I should try, and I hope you choke on your own smegma.
