Re: Morini M01 engine
Slug Scouten /
> Moped Lar wrote:
> > Benjamin The Wandering Pacer wrote:
> > Actually, this is half right. The MO1 / 2 bottom mount is narrower. So
> > on older frames that use them you wouldn't be able to mount an M1
> > without moding the mount. You can mount an MO1 / 2 to an M1 frame but
> > would need spacers for the bottom mount. And yes the M101 is a longer
> > engine so it won't match up. :D
> I must have worked only on older frames, because I’ve never been able to
> transplant an M1 on a M01/M02 frame without mods to the lower mount.
Maybe its the new m1's, like the post 85's? Ive swapped my 78 Polini M1 to a few frames with no issues, or maybe I just got lucky!
Either way lets get this guy an M01!
This topic is closed because the requested item has been found.
