Re: Morini M01 engine
Moped Lar /
> Benjamin The Wandering Pacer wrote:
> Actually, this is half right. The MO1 / 2 bottom mount is narrower. So
> on older frames that use them you wouldn't be able to mount an M1
> without moding the mount. You can mount an MO1 / 2 to an M1 frame but
> would need spacers for the bottom mount. And yes the M101 is a longer
> engine so it won't match up. :D
I must have worked only on older frames, because I’ve never been able to transplant an M1 on a M01/M02 frame without mods to the lower mount.
This topic is closed because the requested item has been found.
