Re: Morini M01 engine
Benjamin The Wandering Pacer /
> Toledo Riot wrote:
> > Moped Lar wrote:
> > > Luna Moto wrote:
> > > I have a m1 bottom end
> > M1 wont bolt up to an MO2 or MO1 moped frame. Completely different
> > motors.
> Ahhhhh the m01/m02/m1 all use the same mounts, the m101 uses unique
> mounts
Actually, this is half right. The MO1 / 2 bottom mount is narrower. So on older frames that use them you wouldn't be able to mount an M1 without moding the mount. You can mount an MO1 / 2 to an M1 frame but would need spacers for the bottom mount. And yes the M101 is a longer engine so it won't match up. :D
This topic is closed because the requested item has been found.
