Need return spring for Magura left brake lever. I have the perch that has both brake and clutch lever if that makes a difference. Cant seem to find LEFT side anywhere. Can I just grab a generic left brake lever return spring? Thanks all
I can't speak for Magura, but I have salvaged damaged Domino lever springs by unwinding ones with some spring left, stretching them out a little, and tweaking them until they work again. Since many moped brake levers aren't that complicated and many systems have spring action at the brake drum, a repaired lever spring seems to work reasonably well.
Thanks for the info Trent. I appreciate you taking the time. I'll see what I can whip up !
