FS: built Puch e50 with stroker 44mm crank and 70cc Reed kit
Jackerz ! /
Built and ran this on a magnum.
Mint bottom end that I ran through my ultrasonic cleaner before assembly. This is a 99% plug and play ripper setup for those who just want to get riding. No carb included (had this vm20 and filter for 12 years and do not want to sell it) but it will come with everything else.
Deats
-clean e50 with all stock components and stock 2 shoe with blue springs
- treats Reed with 46mm airsal massive head for primo cooling
- stroker 44mm crank and all new bearings and seals
-malossi 4 petal Reed block and mlm vm20 intake
-clean stock set of points with ht coil
Literally mount this to your maxi or magnum and go 50+ with out even trying. Just hook up your lights and blast off into the sunset. Had about 150 miles on it before I pulled it, never got hotter than 320*! No leaks, no headache just a ready to run e50 for those who rather ride than wrench.
$620 shipped for this beast
