Re: Aluminum ZA50 starter caps for sale
Aaron Goldman /
> Mike Boyd wrote:
> I was looking at this beautiful starter cap on my bike and a thought
> occurred to me. One of the irritating things about the ZA50 starter
> cable design is that you have to remove the cable from the starter lever
> in order to get enough slack to raise the starter cap to remove or
> adjust the starter where it attaches to the motor. Since the cable is
> pinched into the lever it is inevitably frayed when you do this.
> Sometimes if you solder the cable end right you can reuse it but a lot
> of times it's too frayed to reuse.
> This aluminum cap is much stronger than the stock plastic cap. Probably
> strong enough that a vertical channel could be cut down from top to
> bottom, just wide enough to allow the starter cable to be extracted if
> you popped the cable housing over the seat at the top of the cap.
> This channel would allow you to remove the cap without removing the
> cable from the starter lever, make adjustments, and pop it back into
> place...
> Thoughts?
I’ve made exactly what you’re describing on my 3D printer and even with shitty PLA they have been working fine. And that’s plastic, I’m 100% sure it will work here.
  Aluminum ZA50 starter caps for saleTopic by: * wormdirt * * wormdirt * 09/11/21 11:25PM
  Re: Aluminum ZA50 starter caps for saleRe: Shawn Skibicki Shawn Skibicki 09/12/21 07:53AM
  Re: Aluminum ZA50 starter caps for saleRe: Chris Straub Chris Straub 09/12/21 12:37PM
  Re: Aluminum ZA50 starter caps for saleRe: Chris Straub Chris Straub 10/04/21 04:26AM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 10/04/21 02:18PM
  Re: Aluminum ZA50 starter caps for saleRe: Charlie C Charlie C 10/04/21 02:36PM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 10/04/21 03:39PM
  Re: Aluminum ZA50 starter caps for saleRe: Kenny Shinneman Kenny Shinneman 10/04/21 03:29PM
  Re: Aluminum ZA50 starter caps for saleRe: pat splat pat splat 09/12/21 01:14PM
  Re: Aluminum ZA50 starter caps for saleRe: Jacob Fulton Jacob Fulton 09/12/21 04:37PM
  Re: Aluminum ZA50 starter caps for saleRe: Graham Motzing Graham Motzing 09/12/21 07:32PM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 09/12/21 09:28PM
  Re: Aluminum ZA50 starter caps for saleRe: Mike Boyd Mike Boyd 09/12/21 09:53PM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 09/12/21 09:57PM
  Re: Aluminum ZA50 starter caps for saleRe: Richard Eberline Richard Eberline 09/12/21 09:00PM
  Re: Aluminum ZA50 starter caps for saleRe: Taylor King Taylor King 09/12/21 11:39PM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 09/13/21 12:18AM
  Re: Aluminum ZA50 starter caps for saleRe: Mike Boyd Mike Boyd 09/25/21 05:47PM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 09/25/21 06:05PM
  Re: Aluminum ZA50 starter caps for saleRe: Graham Motzing Graham Motzing 09/25/21 11:52PM
  Re: Aluminum ZA50 starter caps for saleRe: Mike Boyd Mike Boyd 09/26/21 03:39PM
  Re: Aluminum ZA50 starter caps for saleRe: Charlie C Charlie C 10/04/21 02:15PM
  Re: Aluminum ZA50 starter caps for saleRe: Sir Clip Sir Clip 10/04/21 03:03PM
  Re: Aluminum ZA50 starter caps for saleRe: Ed Salad Ed Salad 10/09/21 09:06AM
  Re: Aluminum ZA50 starter caps for saleRe: Mike Boyd Mike Boyd 10/09/21 06:27PM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 10/09/21 06:46PM
  Re: Aluminum ZA50 starter caps for saleRe: Aaron Goldman Aaron Goldman 10/10/21 03:21PM
  Re: Aluminum ZA50 starter caps for saleRe: Chad Tufts Chad Tufts 06/12/22 08:37PM
  Re: Aluminum ZA50 starter caps for saleRe: Graham Motzing Graham Motzing 06/13/22 10:09AM
