Re: Aluminum ZA50 starter caps for sale
Mike Boyd /
I was looking at this beautiful starter cap on my bike and a thought occurred to me. One of the irritating things about the ZA50 starter cable design is that you have to remove the cable from the starter lever in order to get enough slack to raise the starter cap to remove or adjust the starter where it attaches to the motor. Since the cable is pinched into the lever it is inevitably frayed when you do this. Sometimes if you solder the cable end right you can reuse it but a lot of times it's too frayed to reuse.
This aluminum cap is much stronger than the stock plastic cap. Probably strong enough that a vertical channel could be cut down from top to bottom, just wide enough to allow the starter cable to be extracted if you popped the cable housing over the seat at the top of the cap.
This channel would allow you to remove the cap without removing the cable from the starter lever, make adjustments, and pop it back into place...
Thoughts?
  Aluminum ZA50 starter caps for saleTopic by: * wormdirt * * wormdirt * 09/11/21 11:25PM
  Re: Aluminum ZA50 starter caps for saleRe: Shawn Skibicki Shawn Skibicki 09/12/21 07:53AM
  Re: Aluminum ZA50 starter caps for saleRe: Chris Straub Chris Straub 09/12/21 12:37PM
  Re: Aluminum ZA50 starter caps for saleRe: Chris Straub Chris Straub 10/04/21 04:26AM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 10/04/21 02:18PM
  Re: Aluminum ZA50 starter caps for saleRe: Charlie C Charlie C 10/04/21 02:36PM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 10/04/21 03:39PM
  Re: Aluminum ZA50 starter caps for saleRe: Kenny Shinneman Kenny Shinneman 10/04/21 03:29PM
  Re: Aluminum ZA50 starter caps for saleRe: pat splat pat splat 09/12/21 01:14PM
  Re: Aluminum ZA50 starter caps for saleRe: Jacob Fulton Jacob Fulton 09/12/21 04:37PM
  Re: Aluminum ZA50 starter caps for saleRe: Graham Motzing Graham Motzing 09/12/21 07:32PM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 09/12/21 09:28PM
  Re: Aluminum ZA50 starter caps for saleRe: Mike Boyd Mike Boyd 09/12/21 09:53PM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 09/12/21 09:57PM
  Re: Aluminum ZA50 starter caps for saleRe: Richard Eberline Richard Eberline 09/12/21 09:00PM
  Re: Aluminum ZA50 starter caps for saleRe: Taylor King Taylor King 09/12/21 11:39PM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 09/13/21 12:18AM
  Re: Aluminum ZA50 starter caps for saleRe: Mike Boyd Mike Boyd 09/25/21 05:47PM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 09/25/21 06:05PM
  Re: Aluminum ZA50 starter caps for saleRe: Graham Motzing Graham Motzing 09/25/21 11:52PM
  Re: Aluminum ZA50 starter caps for saleRe: Mike Boyd Mike Boyd 09/26/21 03:39PM
  Re: Aluminum ZA50 starter caps for saleRe: Charlie C Charlie C 10/04/21 02:15PM
  Re: Aluminum ZA50 starter caps for saleRe: Sir Clip Sir Clip 10/04/21 03:03PM
  Re: Aluminum ZA50 starter caps for saleRe: Ed Salad Ed Salad 10/09/21 09:06AM
  Re: Aluminum ZA50 starter caps for saleRe: Mike Boyd Mike Boyd 10/09/21 06:27PM
  Re: Aluminum ZA50 starter caps for saleRe: * wormdirt * * wormdirt * 10/09/21 06:46PM
  Re: Aluminum ZA50 starter caps for saleRe: Aaron Goldman Aaron Goldman 10/10/21 03:21PM
  Re: Aluminum ZA50 starter caps for saleRe: Chad Tufts Chad Tufts 06/12/22 08:37PM
  Re: Aluminum ZA50 starter caps for saleRe: Graham Motzing Graham Motzing 06/13/22 10:09AM
