Iso dellorto throttle cap and slide and spring
Does anyone have any of these parts
Re: Iso dellorto throttle cap and slide and spring
Do you mean the topmost part of the carburetor to which the other parts you need are mounted and also holds the cable--two screws on top? If so, lever choke or cable?
Need top screws top cap choke spring choke lever and a slide
Is this what you need?
